Testing voltage regulator
Old Sep 10, 2019 | 08:50 PM
1stultradpd's Avatar
1stultradpd
6th Gear
Originally Posted by Stiggy
Since the battery and stator tested OK, couldn't you read the regulator right at the battery posts? 14.25 or thereabouts when the engine running is a good regulator. Much higher than that and you have a regulator issue.
Yes I tested it there it's kickin out 13.9-14.2!
Old Sep 11, 2019 | 08:03 AM
Ed Ramberger's Avatar
Ed Ramberger
I had to replace the short red wire that connects to the starter positive post (not the battery cable) on my 2000. It was corroded under the insulation. That will cause issues too.
Old Sep 11, 2019 | 10:48 AM
1stultradpd
6th Gear
Ok, thank you much!!
El Chiguete
Electrical/Lighting/Alarm
Jun 24, 2017 10:39 AM
DenimBlackFatBob
Sep 9, 2016 08:02 PM
dochawken
Aug 2, 2015 07:33 PM
Florida Swamp Yankee
Jun 4, 2012 09:43 PM
Randolf06
Nov 3, 2008 07:23 PM
