Ive got a Sportster 883 pre-2000 which wont start. No power to lights or ignition etc. Ive had the battery off and charged and working fine.
Checked 4 fuses on the side panel next to the battery, which are fine. But i cant find the 30amp fuse/circuit breaker to see if this needs to be replaced?
Also follow the ground cable from the battery to the chassis ground. That connection often corrodes and prevents power from getting through. Even a weak battery would show SOME signs of trying to start, or at least run the lights.. sounds like a corroded terminal to me.
