turn signals
Old Mar 22, 2020 | 11:27 AM
mark16w's Avatar
mark16w
Default turn signals
Hello Im Mark from the Netherlands Amsterdam
sorry for my bad English.
I own a electra glide 2002.
just put led turn signale front and rear.
now the first 5 blinks they acting normal but after that they go faster than normal.
I have also have a radiantz fleekz module for my rear turn brake and running
i already put 1 load resistor between the rear left turn signal
but they stil going fast
Old Mar 22, 2020 | 12:30 PM
RANGER73's Avatar
RANGER73
How'd you wire the load equaliser? It doesn't look correct.
Old Mar 22, 2020 | 12:34 PM
mark16w's Avatar
mark16w
I put it in line between the possitive + wire
should connect one side to positive and one side to negative ?
Old Mar 22, 2020 | 12:40 PM
RANGER73's Avatar
RANGER73
You just said 2 different things.
You connect it like its a light bulb, in parallel.
1 wire connected to the hot wire that goes to the bulb and the other wire to ground.
Old Mar 22, 2020 | 12:41 PM
RANGER73's Avatar
RANGER73
You need 1 LE for Right side and 1 LE for the left side.
Old Mar 22, 2020 | 01:08 PM
mark16w's Avatar
mark16w
thank you verry much
so if I connect 1 left and 1 right LE under the fairing to the front it’s also working for the rear ?
Old Mar 22, 2020 | 04:48 PM
RANGER73's Avatar
RANGER73
Yes. the Turn signal module just needs to see total load. It adds load, (amps) like adding another light bulb.
Rapid is how the TSM lets you know you have a bulb out, it sees less load so it rapid flashes.
Old Mar 22, 2020 | 05:11 PM
mark16w's Avatar
mark16w
thanks
i’m gonna fix it
tbone1957
Jan 2, 2013 07:27 AM
SBW Cycles
Aug 14, 2011 06:41 AM
SBW Cycles
Aug 13, 2011 03:10 PM
bharvey60
Oct 27, 2008 07:34 AM
Talent Scouter
Sep 1, 2006 09:20 PM
