LED Turn signals
Old Dec 30, 2012 | 10:26 PM
tbone1957's Avatar
tbone1957
Stage III
Default LED Turn signals
I have a 2012 Road Glide Ultra I would like to switch over to custom dynamics led turn signals. The question i have is if I go to a brake turn run signal on the rear would I order 1157 clusters or 1156. I thhink the stock rear turn signal is a 1156.
Old Dec 30, 2012 | 10:36 PM
Juan L's Avatar
Juan L
Moderator
You want the dual filament bulb used for turn/stop.
You do realize you'll have to wire for that option right and it isn't plug and play?
Old Dec 30, 2012 | 10:39 PM
Redbeard719's Avatar
Redbeard719
Dual filaments, I believe - 1157s.
Old Dec 30, 2012 | 11:38 PM
tbone1957's Avatar
tbone1957
Stage III
Default Plug & play
I don't think you need to rewire anything, Biketronics makes a plug & play to turn your rear signals to Brake Turn Run They call it the tail stopper I'm just wondering if I can use 1156 clusters or 1157.
Old Dec 30, 2012 | 11:46 PM
Juan L's Avatar
Juan L
Moderator
I see now.....
http://radiantz.com/index1.html?411.html&1
Old Dec 30, 2012 | 11:48 PM
DenimX's Avatar
DenimX
5th Gear
If you have the center tail light and separate blinkers you need 1156 lamps and custom dynamics sells a module called the triple play. That will handle run brake turn you will also need to purchase the proper load balancer for the leds. Both should be plug and play.
Old Dec 30, 2012 | 11:56 PM
Uncle Paul's Avatar
Uncle Paul
On my 12 street glide I installed the Radiantz LED's.
Simple plug and play, and no extra compensator electronics needed.
The Street Glide uses just the two turn signal bulbs to serve as turn, stop and running lights. Wanted to get something brighter on there.
Old Dec 30, 2012 | 11:57 PM
drukanfu's Avatar
drukanfu
http://www.customdynamics.com/harley...gnal_retro.htm
Old Jan 1, 2013 | 06:07 PM
pastime's Avatar
pastime
If you're not sure, email or call Custom Dynamics. I've used them and they're very responsive....great customer service. Good luck.....you're gonna love your LED's.
Old Jan 2, 2013 | 07:27 AM
Garemlin's Avatar
Garemlin
The Ultra uses a 1156 single filament bulb. Unless you rewire a new socket you will still use a single filament bulb even when using a r/t/b module.
marktruckee
EVO
Jan 19, 2018 05:15 AM
Sledge
Nov 10, 2012 01:34 PM
bpav16
Apr 29, 2012 07:32 AM
SBW Cycles
Aug 14, 2011 06:41 AM
SBW Cycles
Aug 13, 2011 03:10 PM
