95 electra glide, changed out bars to apes. Previous owner had did this as well. He used mismatched colors to connect the wires, so I had to guess what went where. Anyways... my horn button now turns my headlight on. I figured if I just switched the two wires, done deal, well that didnt work. I just got the bike, and service manual is on order, but need some help please. I also cant find the fuse box. I'd appreciate anyone's help.
Your bike doesn't have a fuse box, it has a handful of circuit breakers, probably inside the batwing or mounted on the front of the top fork tree. Your bike is an Evo and you will get plenty of help if you go to the dedicated Evo section. Someone over there will, hopefully, have a '95 manual they can check for you.
