2007 Dyna ECM
Old May 14, 2020 | 11:46 AM
millhillen's Avatar
millhillen
6th Gear
Default 2007 Dyna ECM
I have a 2007 Dyna FXDL lowrider that has a bad ECM or I have been told because the diagnostic read out says no passcode, I cannot afford a new ECM ($360.00) and pay the dealership 50-100 to program it. I can find a lot of used ECM with the same manufacturer number but none with the same part number. My question is do anyone know of a cross over chart that will tell which year and models will interchange. I do know that unless it is the same year and model as mine it will have to have it re-programed.
Old May 14, 2020 | 09:58 PM
Zerk's Avatar
Zerk
Are they mated? I don't know. If not just get another dyna or softail ECM, providing you don't have a stage one, or find one that does.
If you have a SERT they do mate to the ECM. So if you get another ECM you are screwed **** you Harley and other tuners. At that point do you want to spend the money on tuner that replaces ECM. Though is money is an issue, you won't be doing this.
Old May 15, 2020 | 11:58 AM
nevil's Avatar
nevil
Can't imagine a dealer trying to sell you something you don't need. Right? Sometimes all they know how to do is throw parts at a problem.
Exactly what is the problem with the bike?
Old May 15, 2020 | 12:31 PM
millhillen's Avatar
millhillen
6th Gear
Zerk
I don't have a clue of what you are talking about when you say stage 1 ,SERT, and tuners. If you don't use lehman terms I won't understand.
Old May 15, 2020 | 12:43 PM
millhillen's Avatar
millhillen
6th Gear
nevel
It wasn't the dealership that told me the ecm was bad. It was a friend of mine that owns a custom motorcycle shop. I have a lot of strange things happening to my motorcycle. first the turn indicator lights stays on and the signal light stay on but don't blink even when my switch key is not even in the switch, also my speedometer does not work (electric). and my starter will not engage using the start button on the handle bar. even the dealership says they have never seen anything like it. I put a starter push button and it works just fine. the few people I have talked to agrees that it has to be the ECM.
Old May 15, 2020 | 08:31 PM
Ed Ramberger's Avatar
Ed Ramberger
32534-05c Was the first ECM capable of closed loop. That was actually the 06 ecm on the 06 closed loop dyna. I believe they are on -11 now.
Old May 16, 2020 | 08:30 AM
millhillen's Avatar
millhillen
6th Gear
All due respect to all that answered my post but all I'm wanting to know are there a cross over list somewhere that will tell me what year and model of ECM unit that will interchange with my motorcycle.
Old May 16, 2020 | 12:30 PM
nevil's Avatar
nevil
I don't think such a resource exists. Not just with ECMs but with most other parts. It looks like Ed gave you something to follow up on.
Old May 16, 2020 | 01:55 PM
Ed Ramberger
others fit too. The -05c gets you past the first run of ecms that had some internal failures. I can give another pn that works but not home at the moment.
Anything with an 01 or 04 pn will not support O2s
Old May 16, 2020 | 11:56 PM
Zanthamos's Avatar
Zanthamos
Ok, first off none of the issues that you described are ecm related, looks more like HFSM (Hands Free Security Module) issue not an ECM issue. Turn signals and start both go through the HFSM.
jbyrd1173
May 23, 2011 12:37 PM
my07dyna
Jun 21, 2007 10:18 AM
MAchonewon
Apr 23, 2007 01:54 AM
dlongo8241
Nov 26, 2006 12:47 PM
cnielsen4130
Exhaust System Topics
Oct 13, 2006 12:35 AM
