Headlight issue
Old May 31, 2020 | 06:07 PM
Shaun Landon's Avatar
Shaun Landon
Stage I
Default Headlight issue
Hello,
I have a 2003 Harley Softtail Standard Anniversary edition. The ignition completely died and would only turn on in acc mode. Replaced the switch still nothing. Replaced the starter really and nothing. Replaced the main circuit breaker and nothing. I then checked the voltage to the switch and I have my voltage there. Then when i flip it to acc the voltage is still there. Then when I switch it over to IGN the voltage disappears. For giggles I started pulling fuses. I pulled the lights fuse and it turned right on in IGN. I then disconnected the rear lights plug and it turned right on. Last I pulled the headlight bulb. With the bulb out the bike turns on. With the headlight bulb in the bike will not turn on. The ground wire is shorted to ground and the yellow and white are open to ground. Then when I plug in the headlight bulb all wires are shorted to ground. I cut the wires one by one from the headlight dimmer switch and with the headlight installed they are still to ground. Tried jerry rigging a new ground wire separate from the back wire and it still all grounded. So I am not sure of why the yellow and white wires are shorted to ground with the light bulb installed and open to ground with it not installed. Neither of the wires by themselves are shorted to ground.
Any suggestions from anyone would be greatly appreciated. Thank you.
Shaun
Old Jun 1, 2020 | 06:27 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Your troubleshooting methods make no sense..
First thing, charge the battery and have it load tested.
Once you have a known good battery you can troubleshoot, if the problem still exists...
Old Jun 2, 2020 | 09:58 AM
grbrown's Avatar
grbrown
You've probably done enough damage to warrant finding a local indy to put things right!
Old Jun 2, 2020 | 10:57 AM
Zanthamos's Avatar
Zanthamos
Change ignition switch, that year model has a switch that gets moisture and creates corrosion inside.
Old Jun 2, 2020 | 01:41 PM
Dan89FLSTC's Avatar
Dan89FLSTC
He already changed the ignition switch...
Symptoms sound like a dead battery.
Old Jun 2, 2020 | 04:52 PM
Ed Ramberger's Avatar
Ed Ramberger
You do not understand what you are doing and should stop.
The reason you are getting a positive wire to ground with the light bulb INSTALLED is the FILAMENT in the bulb. With the bulb out it is open as you seem to state. A bulb filament connects positive and negative wires - that's how the filament glows.
Take it to someone who knows what they are doing.
Old Jun 2, 2020 | 05:00 PM
Dan89FLSTC's Avatar
Dan89FLSTC
That kind of suggestion really pisses off the folks who sell electrical parts, like starters, ignition switches etc...
trashtrucker
Jul 24, 2017 05:45 PM
flhsport
EVO
11
Jul 31, 2016 06:23 PM
rags
Sep 29, 2015 05:17 PM
berndog
Shovelhead
Jul 18, 2014 09:33 PM
Zack Bradley
Aug 24, 2012 09:49 AM
