2007 FXDL Ignition Issue
Old Jul 20, 2020 | 09:36 PM
Ben Francis's Avatar
Ben Francis
Default 2007 FXDL Ignition Issue
Hello, I recently snaked my control wires through my bars. Once done I put bike back together and tried to start it. The bike will crank but won't turn over. I checked the plugs and I am getting no fire (used a spark tester).
I'm scratching my head as to what could have caused it, everything is insulated and nothing should be grounding to the frame. I remember I accidentally plugged in the Brown//White wire (right turn signal) into the Black/White wire (starter switch:engine stop run) and flipped cranked the bike (See screenshot of wiring schematic). Could this have caused ignition coil issues or worse, ECM issues?
When key is turned on all electronics come on, when I flip to run the fuel pump comes on, when I hit start the bike cranks. Just no fire.
Yes mistakes were made but any help would be greatly appreciated.
Old Jul 22, 2020 | 07:25 AM
Crotonrz's Avatar
Crotonrz
Does bike have a tachometer, and does it register RPM's at all when you're trying to start it?
Old Jul 22, 2020 | 11:18 AM
Ben Francis
Default Bike is Running
It was. I had a B1122 diag code. I assume from the wires done wrong. I cleared the codes. I checked all fuses and they were fine. I replaced them just in case, unplugged and plugged security system in, got new plugs. And the bike started right up. Not really sure what was going on but it seems fixed as of now.
Ben Francis
Jul 21, 2020 04:09 PM
HYPErob
Jun 18, 2017 10:12 PM
MRCParkerJR
Apr 20, 2013 09:11 AM
nightsterboy
Jul 4, 2008 09:22 PM
Knappy
Mar 16, 2008 07:26 AM
