Bike its dead.
Old Sep 30, 2020 | 06:59 PM
gabriel9102's Avatar
gabriel9102
Default Bike its dead.
I removed the engine and transmission from the frame to paint. Installing again in the frame, I connected all the parts, starter motor, handlebars, battery. When I turned the ignition key, nothing, no sign, the motorcycle seems to have no electricity in the system, apparently the ground cables are correct, fuses too, but there is no voltage in the max fuse. If anyone has a suggestion I appreciate it, I have no idea where to look.
Old Sep 30, 2020 | 07:27 PM
Zanthamos's Avatar
Zanthamos
What year/model? Check battery connections, you may have missed the main harness connection and just got the starter solenoid.
Old Oct 1, 2020 | 12:17 AM
Zanthamos's Avatar
Zanthamos
There should be 2 power wires either on the battery or on the power for the solenoid depending on what model. Main harness main power comes from the second power wire.
Old Oct 1, 2020 | 06:08 AM
BelchFire's Avatar
BelchFire
I replied to your other thread in the Dyna forum. Check the ground where you just painted; it's probably not getting a good ground.
Old Oct 1, 2020 | 06:24 AM
army_eod's Avatar
army_eod
open circuit
Old Oct 1, 2020 | 08:06 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by army_eod
open circuit
Ya think?
gabriel9102
Oct 3, 2020 11:26 AM
hwyfever
Jan 4, 2020 10:28 AM
brimic
Electrical/Lighting/Alarm
16
Oct 8, 2015 08:45 PM
big98
Jun 16, 2012 12:53 PM
stnemason
Sep 3, 2009 07:03 PM
