2010 Ultra. Left turn signal keeps coming on. To turn it off I have to push the turn signal button twice. It will happen again and again. Any ideas of the cause/ fix?
Something is applying voltage to the wire that tells the turn signal module to turn on the left signal.
That might be wires rubbed together. You have a positive wire going to the switch and a wire out of the switch going to the TSM (turn sig module).
If you had a wire going to ground you would most likely be blowing a fuse.
Have seen this happen when the extended switch tabs were added and didn't let the switch completely return out.
In other words it was just barely keep the switch engaged off and on at times.
Anything recently worked on at the bars or switches???
