Led lights
Old Feb 14, 2021 | 06:09 PM
Jeff Dodson's Avatar
Jeff Dodson
Default Led lights
2010 EG.... I converted lights, front and rear as well as turn signals.... I get the hyper flash after 4 blinks, I know I need a register. I also get the security key light on my dash. Its a Police bike so there is no security system on it. Whats causing the light on the dash. The new LED LIGHTS are are working as they should...
Old Feb 14, 2021 | 10:18 PM
Vernal's Avatar
Vernal
I believe it means there is an active trouble code, Check them, try to clear it and see if it comes back.
https://www.fuelmotousa.com/p-29661-...es.html#pcodes
Old Feb 15, 2021 | 08:47 AM
Zanthamos's Avatar
Zanthamos
Security light indicates a DTC has been set, this will likely be the B1126 and B1127 codes for turn signal bulbs. You can do the Trip switch DTC check to see and attempt to clear them but they won't clear until you install the load balancer. Custom Dynamics has a plug in signal stabilizer that works well.
Jeff Dodson
Electrical/Lighting/Alarm
Feb 14, 2021 06:10 PM
Matt Hort
May 15, 2020 08:45 AM
dyna bob 583
Jun 15, 2016 12:25 AM
Charlie Anible
Mar 14, 2016 08:29 PM
Mr. Mobey
Oct 19, 2006 01:52 PM
