Hey all,
I have 2 switches on my 05 RK and they are wired separately for each passing light. One switch is broken from the spade connector. Looking for tips on how to wire them so they are on the one switch as I’m sure they shouldn’t be on the separate switches?
Run the 2 grey wires together to one switch and the other side to a switched power source. Not too hard to do. It should be one switch to aux lamps the other for Accessories connector, the one on the left is passing lamps.
