Ground issue
Old May 6, 2021 | 07:36 PM
nadajoey's Avatar
nadajoey
Default Ground issue
Hello, I was installing a new taillight on my 04 Softail. 3 wires, ground(black), running(red) and brake light(blue). I connected them to the bike’s harness and it doesn’t work. When I bench tested the light it works fine.
now...did another test and connected my wires and isolated the ground wire. Touched a metal part of the frame and boom...lights worked!
so clearly my ground in my bikes wire harness is faulty.
my question is, can I run a separate wire from the ground post near the battery to the back of my bike and connect it directly to the taillight?
is there any issues doing this?
thanks!!!
Old May 6, 2021 | 07:42 PM
kel03's Avatar
kel03
Sounds like you've solved your own problem.
Old May 6, 2021 | 08:02 PM
nadajoey's Avatar
nadajoey
So I am guessing wiring a separate ground isn’t going to cause any further issues, correct?
Old May 12, 2021 | 03:13 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
A separate ground wire won`t hurt a thing.
Old May 12, 2021 | 03:17 PM
nadajoey's Avatar
nadajoey
Excellent. Never hurts to be safe before proceeding. Appreciate the feedback.
UltraDuff
Jan 5, 2014 02:19 PM
armyglide
VRSC Models
Sep 25, 2012 02:35 PM
Joshua Thompson
Apr 5, 2012 10:20 AM
R_W_B
Jan 5, 2011 05:21 PM
zenwarrior
Apr 29, 2007 08:57 PM
