starter drag
Old Mar 24, 2023 | 06:04 AM
gregjo1948's Avatar
gregjo1948
Default starter drag
1984 Super Glide 1340 Evo 1340cc--Rebuilt starter and new starter solenoid--the starter drags so much; it doesn't roll over. The problem is the stater gear is binding on the clutch gear. The bearing in the primary cover is good and lubricated. The two alignment dowels are both there and in good condition. If the cover is forced upwards, it cranks over as it should. How can I remedy this problem? thanks, gregjo1948
Old Mar 24, 2023 | 06:57 AM
touchdown's Avatar
touchdown
Maybe put washers on the bolts to line up right ie: shim it..
Old Mar 24, 2023 | 07:06 AM
bustert's Avatar
bustert
replaced the bendix also????
which starter, back when there was prestolite and delco and they do not interchange parts.
Old Mar 24, 2023 | 09:56 AM
gregjo1948's Avatar
gregjo1948
There are no bolts to shim that would do anything.
Old Mar 24, 2023 | 10:02 AM
gregjo1948's Avatar
gregjo1948
The bendix works as it should. The problem is the gear that the bendix operates, is running too close to the clutch gear, making it bind and crank over too hard.
Old Mar 25, 2023 | 08:20 AM
bustert's Avatar
bustert
the problem is not the bendix not working, it is the correct gear. that said, chinesium aftermarket part?? sometimes a dud.
Old Mar 25, 2023 | 08:31 AM
bustert's Avatar
bustert
correction not delco, hitachi
Shovel83
Shovelhead
Oct 6, 2023 03:57 PM
Rusty Axle
Shovelhead
Nov 4, 2017 01:39 PM
jurgie
Engine Mechanical Topics
Apr 17, 2017 07:24 PM
jtyson
Shovelhead
Jul 21, 2015 03:40 AM
thegreenone299
Ironhead
Apr 18, 2009 02:21 PM
