lighting issues
Old Jul 19, 2023 | 09:34 PM
Nomad1959's Avatar
Nomad1959
1st Gear
Default lighting issues
I have a 96 heritage softail classic and i switched to led. worked fine at first, then headlight went out. I thought i had blown something so i park and start to get off and light comes back on when i turn bars all the way to the left. freakiest thing i have ever seen!
Anyone have any suggestions?
Old Jul 19, 2023 | 09:41 PM
07UltraGuy's Avatar
07UltraGuy
Pull the light apart and check your connections.
If the connections AT the light are solid, it’s possible that the poor connection is internal to the light assembly and likely not repairable.
Old Jul 19, 2023 | 10:11 PM
Nomad1959's Avatar
Nomad1959
1st Gear
i pulled the light assembly out and moved it around with same result. off untill i turned bars all the way to the left, then it comes on. I tried wiggeling both light and wires around to try to localize issue, nothing.
I am afraid i am gonna have to pull tanks, again, and start looking deeper into harness.
Old Jul 20, 2023 | 08:10 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What lights did you change to LED?
Old Jul 21, 2023 | 07:47 PM
Max Headflow's Avatar
Max Headflow
Try going back.. Typically when you have an issue like that it's either a poor ground or a broken wire in the harness at the steering neck..
Old Jul 22, 2023 | 05:14 AM
RANGER73's Avatar
RANGER73
Put the old light back in and see if it still does it.
I had an issue with my H4 plug, 1 of the females is loose in the plug, bike side.
Old Jul 22, 2023 | 05:18 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Stating the obvious but if it only happens when you turn the bars is there a cable getting pulled, pushed or squashed?
Old Jul 24, 2023 | 11:25 AM
Nomad1959's Avatar
Nomad1959
1st Gear
yes, those were my thoughts exactly. I am trying to source a new plug and wires now. anyone know of a company i can get them from?
Old Jul 24, 2023 | 11:33 AM
Andy from Sandy
The FSM will have a list of all the connectors on your bike. If the attached document works you will see HD part numbers and a cross reference.
jimando
Electrical/Lighting/Alarm
Jan 22, 2023 07:53 PM
Pasta.77
Oct 28, 2019 10:19 AM
Liddell1687
Sep 11, 2018 10:34 PM
Jeffcruz
Apr 4, 2018 02:24 PM
lou33
General Topics/Tech Tips
18
Mar 28, 2014 04:16 PM
