Help!
Old Sep 15, 2023 | 05:13 PM
HARLEYGIRL2016's Avatar
HARLEYGIRL2016
Lol my brain has exploded with this. I have it on a tender. The lights I took off were not working properly. But it was a different problem. But they were also LED lol. The dealer said if the blinkers don’t go crazy I shouldn’t need a….. whatever that thingy is called 🤓 thanks for tryin!
Old Sep 15, 2023 | 05:35 PM
WP50's Avatar
WP50
Do you have an ol fashion test light, one with an incandescent light bulb in it.
The incandescent bulb puts more load on the circuit while testing.
Helps to insure you have enough current to make things work correctly.
WP
Old Sep 15, 2023 | 05:37 PM
HARLEYGIRL2016
My test light has a red bulb
Old Sep 16, 2023 | 08:02 AM
WP50's Avatar
WP50
Didn't think about this till this morning.
Measure the resistance on the ground circuit.
Open or high resistance can cause what you describe
WP
Old Sep 16, 2023 | 09:29 AM
HARLEYGIRL2016
Okay my meter does weird things, this is where I’m NOT very knowledgeable. But I took the wiring harness ground out of the equation, made a frame ground hooked up light and still have the same problem. Think I am just going to order the original style and forget this mess…..
Old Sep 16, 2023 | 10:42 AM
WP50's Avatar
WP50
On a 2012 you may have Load Equalizers since I think you mentioned had Led to start with when you got it.
Just remembered that this morning to.
Those can create some odd problems also.
There's all kinds of load equalizers
This is only 1 example https://video.search.yahoo.com/yhs/s...177ec00fe5afa3
Good Luck WP
Old Sep 16, 2023 | 10:46 AM
rigidthumper's Avatar
rigidthumper
On the bike side:
Black is ground
Blue is running light (dim)
Brown is right turn signal
Purple is left signal
On the LEDs
Black is ground
Blue or yellow is running light
Red or orange is turn signal
WideGlide14
Sep 29, 2019 07:53 PM
Robtarra39
2014-2024 Touring Models
19
Feb 18, 2017 04:04 PM
bfgoodmudder
Jul 31, 2011 11:26 PM
goodryde04
Electrical/Lighting/Alarm
Mar 15, 2011 10:39 PM
goodryde04
Mar 12, 2011 07:16 AM
