Tail light blinking with turn singal
Old Feb 15, 2024 | 11:19 AM
BravoKilo's Avatar
BravoKilo
1st Gear
Default Tail light blinking with turn singal
I have a 1994 Fatboy, and I recently replaced the rear fender with an original one. Additionally, I bought a new set of turn signal lights and a new LED tail/brake light. I installed everything correctly, but for some reason, the brake light is blinking along with both turn signal lights. I used brand-new cables for the entire setup, so I don't think there's any interference from a damaged cable. It's odd; I grounded the tail light using its bolts, but the same issue persists. The turn singal lights are not LED.
Old Feb 16, 2024 | 08:21 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Sounds like the LED tail light is not compatible with incandescent bulbs. Try it with the original tail light. If it works, bad LED tail light.
Old Feb 16, 2024 | 11:41 AM
Buelligan666's Avatar
Buelligan666
Try a ground wire directly from the battery just to eliminate the possibility of bad grounding.
Old Feb 16, 2024 | 02:28 PM
RANGER73's Avatar
RANGER73
How did you wire the new turns/
The 94's turn are turn only, no ground wire, only 1 wire to each side from the TSM.
The original tail/brake light is just that, tail/brake. only 2 wires.
What did you do for connections?
Peter Clevenger
May 16, 2021 05:42 AM
kingomtn
Dec 28, 2011 11:39 PM
D2MOTO
Jan 28, 2011 01:28 PM
TiminCanada
Mar 17, 2010 11:55 PM
The Old Man
Jan 7, 2010 07:46 PM
