speedo d codes..D10set
Old May 11, 2024 | 05:50 PM
Cdex0614's Avatar
Cdex0614
Default speedo d codes..D10set
2002 Road King d10set code. Bike runs fine just has an intermittent engine light come on.
Just replaced the VSS and cleared the code at the speedo and engine light came on again with D10set code.
Speedo does not jump around wildly like other VSS issues I've seen but It does go from 0 to 1-2 MPH when in neutral when revving it to check regulator at battery.
Batter voltage is 12.6 sitting
11.2 starting
14.3 at idle and 14.5 and about 2k RPM.
I don't have a OBD but was going to run up to my HD dealer and have them pull code off of the ECM unless you guys got a solution or 2.
Bailey78
Jul 5, 2023 03:21 PM
ajames01r
May 22, 2018 07:39 PM
sdshook
Mar 13, 2010 05:35 PM
robfaulkner
Aug 15, 2008 01:08 PM
mikejunior7
May 12, 2008 10:51 AM
