Ignition Switch - Intermittent Power Loss
Old Sep 29, 2024 | 08:12 PM
Kevin Polzer's Avatar
Kevin Polzer
Default Ignition Switch - Intermittent Power Loss
Greetings, 1984 FXST. Bike cut off on me the other day. Replaced the battery and it starts now but there is something weird going on with the ignition switch (same problem even after installing a new one). When the switch is in the on position, the slightest vibration will cause the power to go out. I noticed if I jiggle the ignition switch, while remianing in the on position, the power turns off and on.
Have issues uploading video here so I added the link below.
https://youtube.com/shorts/pViPYcFx6i0?si=FUC-VlWD5Ht6N05s
Old Oct 1, 2024 | 07:55 PM
TexasScooterTrash's Avatar
TexasScooterTrash
That's the old 6 pole ignition switch. Ohm test both of the switches for continuity for ignition and lights/ignition. Bypass the switch and hot wire it. That eliminates a bad ignition system and wires. Sounds like worn out switch contacts. Might be time to update to a 3 pole switch.
Old Oct 3, 2024 | 02:13 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Buy an OEM switch.
Old Oct 5, 2024 | 07:30 AM
Baird's Avatar
Baird
Colony makes a replacement roller contact. Yours probably has flat spots.
Old Oct 5, 2024 | 04:32 PM
Max Headflow's Avatar
Max Headflow
Replace your main circuit breaker.. Make sure the terminal lugs are in good condition.
Clas
Electrical/Lighting/Alarm
Oct 26, 2019 09:03 PM
gsbuick65
Jul 17, 2018 01:58 PM
claimjumper2013
Jun 25, 2017 10:37 AM
steelpony16
Apr 10, 2015 03:53 PM
ccmdawg
Jun 21, 2007 04:44 PM
