2013 Fatboy lo 103ci ignition switch problem?
Old Jun 23, 2017 | 04:20 PM
claimjumper2013's Avatar
claimjumper2013
Stage II
Default 2013 Fatboy lo 103ci ignition switch problem?
Will not start at times. Will some times cut of and lose all electrical power while running down the road, wiggle the ignition switch some and will start back up. Now some times when starting bike will just click and not start. Wiggle the switch and may start. Wires to switch are very small so no heavy power is carried. Could it be a module?
Old Jun 23, 2017 | 06:49 PM
bad tappets's Avatar
bad tappets
If wiggling the ignition switch solves the issue, then it's probably the switch. Disassemble, clean contacts, put back together and ride.
Old Jun 25, 2017 | 10:37 AM
claimjumper2013
Stage II
Cool 2013 Fatboy ignition switch problem
Thanks for the info. Will try that. Have older Harley where the switch carries all the power, wasn't sure about this beast..
PoincianaRoadKing
Apr 21, 2020 02:13 PM
gsbuick65
Jul 17, 2018 01:58 PM
mixham
May 15, 2016 08:19 PM
Deborah Scott
Jul 21, 2013 12:36 PM
klagair
Apr 6, 2006 06:43 AM
