Stumped
Old Dec 30, 2024 | 03:31 PM
junebugjones's Avatar
junebugjones
6th Gear
Default Stumped
Ok, so 2010 wide glide. Just changed the bars along with extended wiring from Burly. Now the right turn signal does not work. Checked the wiring with a circuit tester and it lights up as it should. Switched the left for the right and it works. So appears to be the unit. (LED). Bought a new one. Same thing. If it was the LED controller, I would think I would not even get the circuit tester to light up. Also, it will flash when I shut the ignition off as is should for the antitheft. I never noticed it not working prior to changing the bars but who knows. Any suggestions?
Old Dec 31, 2024 | 02:43 AM
junebugjones
6th Gear
Disregard. Figured it out.
Old Dec 31, 2024 | 08:55 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Anxious to know how you fixed it....
Old Jan 1, 2025 | 07:10 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
@junebugjones It would be a simple courtesy to tell us what the solution was.
Old Jan 2, 2025 | 03:49 AM
junebugjones
6th Gear
Relax. I simply repinned the plug wrong. Simple fix. Must have had my head wrong to not think of it before.
josephtvillarreal
Sep 8, 2022 05:00 PM
Jackpoticorn
Jun 3, 2018 09:56 AM
hemi1300
Oct 9, 2016 12:38 PM
Johnnypbravo
Aug 14, 2013 10:44 AM
weejohnnie
Oct 29, 2010 08:29 AM
