Tail Fail!
Old Jun 2, 2018 | 06:38 PM
Jackpoticorn's Avatar
Jackpoticorn
Default Tail Fail!
Just installed new LED taillights last weekend - run/brake/turn. Everything was fine until today, noticed the right side was out. Pulled the wiring, nothing obviously loose. Turned bike on, both lights come on, but as soon as I squeeze the brake lever or hit the right side turn signal button, the right side dies until I turn the bike off and on again. Any ideas?
Of note - the LED signals aren't 3 wire - they are 2 wire with a supplied converter/splitter (called a dual element circuit set) for each side's hot wire.
Old Jun 2, 2018 | 09:35 PM
Jackpoticorn
Update - I disconnected the right side LED and wired in the old turn sig - everything works. I'm guessing it's something to do with the LED itself or the dual element converter...
Old Jun 2, 2018 | 09:53 PM
STRES's Avatar
STRES
Can you swap the lights and see if the problem follows the light or the wiring.
Old Jun 3, 2018 | 09:56 AM
Jackpoticorn
Good call I'll switch the harnesses and see what happens!
fporfido3
Apr 10, 2019 04:24 PM
Gasitman
Electrical/Lighting/Alarm
Dec 9, 2012 07:07 AM
Lourance23
Aug 10, 2012 10:46 PM
gnormous
Jul 9, 2012 11:28 AM
SMSgt B
Oct 24, 2010 09:44 AM
