99 evo ignition always powers lights
Old Jul 15, 2025 | 08:25 PM
Dseago1969's Avatar
Dseago1969
Default 99 evo ignition always powers lights
Unknown 99 evo Softail that has been worked on and ready to run. It is put together the way it came apart with a few wiring modifications. I have 2 issues and maybe someone can offer me a solution. Led light up horn cover but one wire was always soldered in. The other was left loose so it didn’t light up, I grounded and it is always on no matter the ignition position. Minor and I could tape off.
The other issue is the back running lights are always on.
I did a few minor changes from the original wiring going to the exact places as before when I relocated license plate.
Is there a chance the ignition switch is wired wrong. If so which one would let power through all of the time. I looked at the service manual but I’m not clear.
Old Jul 16, 2025 | 07:28 AM
bustert's Avatar
bustert
tie the horn led to the system lighting and ground the other side, maybe polarity sensitive. running lights are on with ignition off? running light are supposed to be on, hence the word "running".
what switch do you have? off/park/ignition or off/ignition/lights which was the old way but big brother forced the headlight on with key on to help stupid cagers see ya!!
Old Jul 16, 2025 | 08:41 AM
Dseago1969's Avatar
Dseago1969
I pulled the dash and found the culprit. Poor solder job for the led lights on the horn and a loose connector to the switch allowed it to touch the power in terminal.
RANGER73
Electrical/Lighting/Alarm
Mar 24, 2017 07:07 PM
jrotis215
Jul 13, 2014 07:27 AM
hippijim
Apr 3, 2013 11:02 AM
Stranger
May 16, 2012 08:53 PM
D1gger
EVO
20
Jul 4, 2011 07:03 PM
