LED TAIL LIGHT/brake light...
Old Mar 13, 2026 | 12:49 PM
slowboy's Avatar
slowboy
Default 1995 REAR BRAKE LIGHT NOT WORKING
Originally Posted by FXD2003Rider
I asked before and ask again: Have you checked with a multimeter or a probe light if you have 12v power at the stoplight wire at the switches and the rear light circuit board when you apply the brake(s)?
I guess red is for stoplight, yellow for runninglight and black for ground.
No...I haven't been able to yet. I've been busy with doctor appointments for AFIB and Lung Cancer treatments. I'll get on it as soon as I can.
Old Mar 20, 2026 | 05:29 PM
slowboy's Avatar
slowboy
Default 1995 Badboy brake lights don't work
I unplugged the 2 wires from the brake light switch. With my probe light, I turned ignition switch on and with both wires removed from brake light switch 'both' wires showed power to them. I thought that the brake light wire should only show power when brake pedal or front lever was pressed. Am I wrong or is there something wrong with the wiring? Plus now the front right turn signal light doesn't work
Old Mar 22, 2026 | 08:25 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Here's how to check:
1. unplug the O/W wire from your stoplight switch
2. Connect probe light clamp to ground at frame
3. Turn ignition on
4. Check with tip of probe light if you have power at the O/W wire. If you have no power check if you have power at the the acc fuse outlet where the O/W wire is connected
5. If you have power at the O/W wire at the stoplight switch unplug the R/Y wire at the switch, apply the brakes and check if you have power at the stud where the R/Y wire was connected. If you have no power you have a bad brake switch. If you have power, reconnect the R/Y wire, apply the brakes and check the R/Y wire at the rear light connector for power. If you have no power, check for a broken R/Y wire. If you do have power the led module went out of order.
Old Mar 22, 2026 | 09:06 AM
twoglides13's Avatar
twoglides13
I had a "Harley Brand" LED taillight on my 05' Wide glide that had LED's go bad one at a time in a very short time. I replaced it with a Bright *** Light and never had a problem afterwards!
dndfishing
Apr 7, 2023 08:00 AM
SIGMACJT
Electrical/Lighting/Alarm
Aug 3, 2021 10:22 PM
ratherdriveatitleist
Nov 3, 2020 03:37 PM
ultradriver
Dec 17, 2016 09:24 AM
cmtaylor
Aug 8, 2013 07:53 PM
