Potential Ground Issue
Old Apr 3, 2026 | 04:46 PM
im's Avatar
im
Turn the KEY switch to ON.
Then go to the RUN/STOP switch on RIGHT handlebar and flip it to ON.
Does that RUN/STOP switch make fuel pump run for about 3 seconds?
*Basically trying to rule-out a malfunction along the RUN/STOP switch OR the wiring to the right hand control.
Old Apr 3, 2026 | 05:35 PM
Vernal's Avatar
Vernal
I asked this in post 13 but never saw a reply:
If the starter will crank the engine the power is at the righthand controls, can you pull the relay and check for 12V at 86? Also put a lead in 85, other lead on ground and turn ign on then off to run and see if you get a brief continuity to ground.
power at 86 would be at the relay coil, if power is there then the question is why the ECM doesn't ground .
Old Apr 10, 2026 | 11:40 PM
Vernal's Avatar
Vernal
@OtterTail05 Did you get it fixed?
Old Apr 11, 2026 | 08:27 AM
OtterTail05's Avatar
OtterTail05
has power at 86 no issue there, when i try 85 to ground with relay installed it does not get a brief ground at key on, but when cycling to off it gets a momentary ground.
Old Apr 11, 2026 | 09:30 AM
Vernal's Avatar
Vernal
@OtterTail05 The W/BK wire also goes to the ECM slot 13, +12V?
996Duc
Feb 6, 2023 01:19 PM
CB899
Aug 9, 2019 01:44 PM
Shdwcaster
Sep 24, 2017 03:58 AM
zschaeff205
Jul 14, 2016 10:41 AM
Houston_t
Dec 11, 2012 03:45 PM
