Brake Light Stays On
Old Jun 11, 2009 | 10:54 AM
theosmithers's Avatar
theosmithers
5th Gear
Default Brake Light Stays On
I have an '01 FLST that I changed the brake pads on last year. Unfortunately, ever since then, after warming the brakes up the front brake lever gets a little play in it and kicks the break light on. It won't go off unless I hold the lever all of the way out. I know that there must be a way to adjust it, but I can't find it on the 'net. Can anyone help?
Old Jun 12, 2009 | 06:06 AM
scrubby64's Avatar
scrubby64
Hi, I'm not sure if the set up is exactly the same on all models, but this happened on my 2000 FLTRI. I cured it short term by taking the brake lever out and putting a blob of JB weld on the "horn" which holds the brake switch closed. Ultimately, I had to re build the master cylinder, the real problem was a sticking seal. Whilst the master cylinder is pretty simple, and the kit inexpensive, getting the brakes bled was a nightmare, took me a weeks worth of evenings...
Old Jun 13, 2009 | 01:08 AM
jimmie d wad's Avatar
jimmie d wad
make sure where your switch housing and lever mount contact each other is tight.on my bike if theres a tinny gap the light will stay on
crabio
Apr 10, 2018 01:20 PM
EJ48
General Topics/Tech Tips
Nov 15, 2016 11:34 AM
Justin Kelly
May 15, 2014 09:09 PM
FireRyder09
Jan 18, 2010 12:44 PM
stang2811
Mar 14, 2008 09:18 PM
