Possible short?
Old Sep 2, 2009 | 10:16 AM
TIPN8R's Avatar
TIPN8R
Question Possible short?
I'm dumbfounded...
Every so often I start the bike whether it's cold or warm and the high
beam light stays on while the headlight is off.
After flipping the hi beam switch on and off for a few minutes and
sometimes just on it's own, the indicator light will go out and the
headlight comes back on. Then it all works normal at that point.
I checked the headlight connection and wires and they are all good. The
headlight bulb is fine too.
I remember this used to happen after I washed the bike and the headlight
switch on the bars got wet.
But it haven't hosed it on the bars in a long time.
Do you think I should take a apart the housing on the bars and check all
connections?
Old Sep 2, 2009 | 11:30 AM
0734's Avatar
0734
If you wash something electrical enough, it will eventually corrode. Even if you stop washing it. If the headlight plug is okay (and they have a history of melting), you don't have many options left but to go fishing and I'd start at the switch.
i
Old Sep 2, 2009 | 12:41 PM
TIPN8R's Avatar
TIPN8R
i
Thanks, figured start out from the top and work my way down...
keno
Jul 30, 2020 01:00 PM
QehQeh
Sep 22, 2013 03:34 PM
CS Mactavish
Feb 3, 2012 09:05 PM
cowhauler
Electrical/Lighting/Alarm
Jan 31, 2011 08:33 PM
animal1975
The General Motorcycle Forum
Jun 25, 2009 12:35 PM
