auxiliary light hook up
Old Jan 17, 2010 | 02:59 PM
wasbig66518's Avatar
wasbig66518
Stage III
Default auxiliary light hook up
just bought a set of passing lamps for a street glide on ebay. have to install a switch to turn them on and off. anyone know how to install the switch and do the hook up? would really appreciate the help...thanks
Old Jan 18, 2010 | 01:16 AM
rufuslee's Avatar
rufuslee
Stage I
Hi,we just made a video for RGB led lighting.pls go to http://u.youku.com/jdlights
For more pls go to www.jdlights.com
Rufus lee
msn:rufus_lee_2007@hotmail.com
Old Jan 20, 2010 | 10:14 AM
UltraNutZ's Avatar
UltraNutZ
Default passing lamp wiring
go down to your local auto store. pick up a 30AMP auto relay
the wiring is as such.
ground wire on lamps go directly to ground.
from your battery source, put an inline fuse of 15 or 20 amps.
put your power switch wherever you want it.
connect your power source to terminal # 30 of the relay
connect your power switch to power also (doesn't have to be anything spectacular just a simple acc or igniton source)
connect the other terminal from the power switch to terminal # 86 of the relay
connect terminal # 85 on the relay to ground
connect terminal # 87 on the relay to the other wire coming from passing lamps
all done.
hope that helps
Todd
Old Jan 21, 2010 | 06:44 AM
wasbig66518
Stage III
Default thanks
todd,
thanks that should be a big help. i'll hook them up this weekend.
brent
FinalShot
2014-2024 Touring Models
Oct 31, 2014 09:33 AM
caltech
Mar 24, 2013 11:04 AM
10Glider
Oct 19, 2010 09:12 AM
tbradley
Oct 2, 2007 01:15 PM
Hoopman
Oct 12, 2005 02:14 AM
