Charging???
Old Mar 20, 2010 | 11:25 AM
davek928's Avatar
davek928
5th Gear
Default Charging???
I have a '68 XLCH that has been converted to a 12 volt ignition. My fully charged brand new battery went dead after a few rides. I recharged the battery and chacked the voltage. I started the bike and checked the voltage at the generator, then at the voltage regulator (right before and right after the regulator), then at the battery. The only possible problem that I found was at idle the generator would sometimes drop to 7 volts. I had the generator tested last year, the shop replaced the field coils and said everything else checked out. Am I missing something or is this common? Should I put the battey tender on it more frequently? I should mention that the bike had spent more time idling because I jut rebuilt the top end and had to run it through a few heating/cooling cycles to seat the rings.
Old Mar 21, 2010 | 12:06 AM
11sec.shovel's Avatar
11sec.shovel
Ya, those oldies dont put out much at idle. It shouldnt drop much below 12 @ idle and put out 13.5+ above 1500 rpm. Maybe short rides and lots of idle time pulled it down.
Old Mar 21, 2010 | 09:30 AM
Captain Itch's Avatar
Captain Itch
Sponsor
The only trouble I had with that setup was having to Excite the fields so it would charge..
__________________
www.Captain-Itch.com
619DYNA619
Aug 8, 2018 10:21 PM
scottiej42
Electrical/Lighting/Alarm
Apr 13, 2015 11:17 AM
Maple Leaf Hog
Nov 7, 2011 07:33 AM
NSCoyote
Oct 10, 2009 04:04 PM
nuera2
Sep 6, 2009 01:33 PM
