Stator Regulator Replacement
Old May 26, 2010 | 10:24 PM
RonnieK's Avatar
RonnieK
6th Gear
Default Stator Regulator Replacement
Hello
Does anyone have any pictures, video's, step by step guides, tips, etc
about replacing a stator on a 2003 Road King? I do have a Harley shop manual, however I am just looking for something more. There is a LOT of knowledge on these forums! THANKS!
Ron
ronnie_k202@hotmail.com
Old Jun 3, 2010 | 05:57 PM
dcfatboy's Avatar
dcfatboy
Default Tips
  1. Make sure stator is indeed bad.
  2. Be careful with (i.e use toll to remove and replace) rotor.
  3. Check rotor for loose magnets or grove in center of rotor (side facing the stator).
  4. WD-40 works well on the stator plug that goes through the primary.
  5. Torque compensator nut properly.
  6. Clutch hub nut loosens CW.
  7. Ensure bolt for regulator ground at transmission exhaust bracket is snug.
  8. If rotor is bad too, consider upgrading to a Cycle Electric alternator kit.
I think that's about it If you have any questions just holla'. I just replaced mine about 3 weeks ago.
Old Jun 3, 2010 | 06:34 PM
dcfatboy's Avatar
dcfatboy
Default Video
here 'ya go: http://www.hdtalking.com/electrical_...r_replace.html
tuekwik4u
Nov 21, 2016 12:14 AM
Knight2
Aug 11, 2014 06:37 AM
mtalolor
Jul 18, 2013 02:31 PM
Dbaum311
May 22, 2012 02:34 PM
twistedcherokee
Aug 13, 2009 07:53 AM
