electrical problem
Old Mar 12, 2011 | 04:06 PM
h2o's Avatar
h2o
Default electrical problem
I recently installed a new kuryakyn tail light which is plug and play and new bars internally wired. Now when I turn on my left side turn signals, there is a slight wine and then neither side works. if I disconnect the rear turn signal, the front works fine. I also blow a fuse when I put on my high beams. The right side works fine. It would be greatly appreciated if someone might be able to give me a clue of what the problem is.
Old Mar 13, 2011 | 03:55 PM
Slipstrm's Avatar
Slipstrm
I doubt the tail light is to blame.
I suspect the wiring in the bars is incorrect.
I'd go back to the original bars and wiring and see what happens.
Old Mar 13, 2011 | 06:58 PM
h2o's Avatar
h2o
That's what I'm thinking or maybe I did something in the bar housing.
Old Mar 13, 2011 | 07:00 PM
soft 02's Avatar
soft 02
Check where your controls clamp to the bars. Many you pinched some wires.
BarleyW83
Jun 26, 2019 10:30 AM
CJeff75
Mar 25, 2018 01:03 PM
janderson1964
Electrical/Lighting/Alarm
Mar 12, 2015 10:47 AM
Dalepac
Sep 29, 2014 08:12 PM
mamabear61089
Apr 21, 2013 09:27 AM
