Please help!!! 2014 Front Turn Signal Relocation problems
Old Sep 29, 2014 | 12:35 PM
Dalepac's Avatar
Dalepac
Stage II
Unhappy Please help!!! 2014 Front Turn Signal Relocation problems
Hope there is help out there. I just purchased a 2014 Fatboy, love the bike, except for the turn signals on the bars. I have checked the threads and haven't found the info needed. Seems the turn signals are hot glued into the handle bar control switches. The lights have 3 wires coming out of them. I can't pull the wiring through the bars. Question do I cut the 3 wires and then tie into the harness on the right side? I haven't seen any 2014 instructions on the web for this. Please help, I'm lost and want it to look right, Thanks
Old Sep 29, 2014 | 12:59 PM
FLS103's Avatar
FLS103
I dont know if there were changes in 2014. I have done a 2013 and the signals were not glued, they screwed into a 5/16" 24 pitch pivoting stud on the mirror/signal bracket. I cut the wires between the tank and the tree and was able to pull them through the bars by loosening the controls. I then attached signals to the forks with 5/16" 24 pitch rod and re- routed the wires, soldered and shrikwrapped. The only place locally to find the rod was Fastnall.
Old Sep 29, 2014 | 01:08 PM
Misbehaven's Avatar
Misbehaven
Read through this write up. It should shed some light on this very subject.
https://www.hdforums.com/forum/softa...fatboy-lo.html
Old Sep 29, 2014 | 02:02 PM
SGTSCARY's Avatar
SGTSCARY
1st Gear
Great set of instructions! Not sure I ever said thanks for posting it! But start to finish about an hour... Only thing I did differently (and I think Misbhaven says it in his instructions) was just cut the wires at the base of the controls then used a set of needle-nose to pull what was left into the housing. The wires that are left are dead so no need to cap them and I actually just left them in the bars.
Good luck with your project.... Post the results!
Old Sep 29, 2014 | 08:12 PM
Dalepac's Avatar
Dalepac
Stage II
Thanks for the help. Nice posting by Misbehaving. Very clear and easy to follow. ��
Killer Bee19
Jun 6, 2014 07:03 PM
Psi23
Dec 13, 2012 05:00 PM
s13_marine
Oct 9, 2011 02:56 AM
FATKEVIN
Jan 22, 2011 11:21 PM
stwesty
Electrical/Lighting/Alarm
Jun 22, 2009 08:28 PM
