Front Signal Questions
Old Nov 19, 2012 | 09:32 PM
Psi23's Avatar
Psi23
Default Front Signal Questions
Been debating on relocating and just straight up removing the front turn signals and have a few questions. For those who have removed did you just cap off the wires at the bars? Also anyone having issues after removing (errors or anything from not having the running lights attached)?
Thanks!
Old Nov 19, 2012 | 09:39 PM
crimson13's Avatar
crimson13
No issues after removing the front signals for me man ,I am fixing to put the front sigs back on the forks though
Old Nov 19, 2012 | 09:48 PM
zukeeper's Avatar
zukeeper
I capped and tucked the wires under the tank. needed a load equalizer to make the rears work correctly.
Old Nov 19, 2012 | 09:57 PM
Psi23's Avatar
Psi23
Yeah, if I remember correctly though when I was installing my bars the signal wires were in the bunch with the rest of the wires and it treed off right at the top so I don't know if I will be able to trace back down to the tank . Also since my bike is a 2012 I was honored enough to have the harley ******* hanging off the back as a rear light so when I throw my bags on tomorrow ill be losing those signals as well, so I don't know if I will have any brake light problems. Crimson when you did your bars do you remember what the wiring looked like on the 2011?
Old Nov 19, 2012 | 11:50 PM
DOMAPOI's Avatar
DOMAPOI
Thanks!
The main issue I can see is with the LEO. California law states that any motorcycle manufactured on or after January 1st, 1973, MUST have turn signals front and rear. And, shall not be mounted lower than 15" from the ground.
Old Nov 20, 2012 | 09:00 AM
Psi23's Avatar
Psi23
Yeah I'm not to worried about them.. I just tell them give me the ticket and save your sob story about other drivers.
Most of my other bikes didn't have signals either
Old Dec 11, 2012 | 09:07 AM
zimm's Avatar
zimm
Not required in Virginia so I took mine off. Now I'm looking for new ones to put back on! When you're trying to turn left at an intersection and cars are coming head-on- it's nice to be able to signal that you are turning. Can't do that with your hand because you're on the clutch and throttle...
Old Dec 11, 2012 | 09:58 AM
Robbie13's Avatar
Robbie13
LOSER
Not required in NC either. Mine have been gone. When I removed the rear center brake light a while back I just used the two turn sigs as brake lights. Those are gone now though since my last mod. The only time I would get a code is when I accidentally hit the turn sig button. It would clear at the next start up though.
Old Dec 11, 2012 | 08:35 PM
jpicht's Avatar
jpicht
Default LED mirrors
If you still want turn signals but don't like the clutter, do like I did. LED turn signal mirrors. Cheap (about $60) and didn't even need a load equalizer.
Bikemaster Candy Drop Custom Naked Bike Mirrors with Integrated Turn Signals (do a google search and you'll find them at a good price)
Attached Thumbnails Front Signal Questions-dsc01008.jpg   Front Signal Questions-dsc01009.jpg
Old Dec 11, 2012 | 09:25 PM
Mangles's Avatar
Mangles
Not looking to take mine off, but is there a way to change them from running lights to just turn signals? Meaning if my signal isn't on, they're not on.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
