After Factory LED Lighting
I'm looking at installing an off the shelf LED "brake, turn signal and running light strip system on my Helmet trunk. The package says it has a control circuit board and does not require a load equalizer because it is not replacing the exiting lights but adding a amp or 2 to the circuit.
Here is the best part, I want to do this on an 08 FXDC w/security. People just can't see me with the single puny light that comes on the bike! I may also convert the exiting lights over to LED later using a much more expensive conversion kit from HD.
Molson9
http://www.customdynamics.com/led_mo...hting_faqs.htm
That circuit is in the TSSM as mentioned.
As far as needing load balancers or resistors... that's easy enough to explain but a bit confusing. If you figure a circuit where power flows into the bulb then out and back to ground.... it will draw a certain amount of power. An LED works the same way, but draws less power. When you add a resistor, you add it in parallel with the LED's, so that when you hit your blinker, power flows through the LED and also through your resistor.
"but don't resistors reduce current". Yep... but for a given ohm value, if you put a voltage into a resistor you will get a current. A bike is around 12 volts, so based on the ohm value you can figure out the current that will flow through that resistor. When you hook it up in parallel with the LED, the total current flowing will be the amount going through the LED plus the amount going through the resistor. That's why the resistor gets it's own connection to the power and ground wires - so that it creates a second path for power to flow.
Getting technical.... if anyone took any electronics classes, Ohms law says V = I * R where V = volts, I = current and R = resistance. Watts is just volts times amps... so a stock 1157 bulb might be 25 watts, which is about 2.1 amps at 12 volts. So if you wanted to get a resistor that created the same current draw as a bulb did,
V = 12
I = 2
So R = V/I which is 12/2 which is 6 ohms. So a 6 ohm resistor connected to 12 volts will flow 2 amps, which is about the same as a stock 25-watt bulb.
Since your LED signal will also draw some power, you would want a little higher ohm rating... so maybe 8-10 ohms would be good.
One other thing to consider is power. A resistor flowing 2 amps at 12 volts is turning 24 watts of electrical energy into heat. If you connected a 1/2 watt resistor (the watt rating is the ability to dissipate power), it is going to way waaaay overheat trying to dissipate 24 watts. It could even catch fire or explode. So you want at *least* a 25 watt resistor, but a 50 would be better (since it has a higher limit, it won't get as hot dissipating 24 watts).
Hope this info helps someone.
