Speedometer problem
Old Mar 22, 2012 | 02:09 PM
drs0413's Avatar
drs0413
Default Speedometer problem
Have an 01 Electra Glide Classic 88 ci with fuel injection. Started having problem with speedometer shutting down then coming back on, cleaned the sensor and no change, replaced sensor and still no change. Had the dealer check it and no change, although they charged me enough, lol. Pulled the outer fairing and visually checked the wiring and everything looked tight. Need the odometer as I don't trust the fuel gauge, although it is pretty close to being accurate, but I've only had the bike 11 years so am still a little suspicious of it, maybe in a few more years will trust it. Any ideas for a fix would be greatly appreciated, and thanks.
Old Mar 23, 2012 | 07:30 AM
UltraNutZ's Avatar
UltraNutZ
if the display is shutting down this is an electrical problem, not a speed sensor issue. So the dealer found nothing wrong or did they say they fixed something and it's really not fixed?
I would start with the speedo itself. Look at the back of it where the plug mates to it. Check the pins in both the speedo plug and the actual wiring harness that plugs into the speedo for bent or loose pins and dirt.
then I would move to the ECM connector. Check the same there for loose or bent pins and dirt. Spray some electrical contact cleaner in all connections at the speedo and ecm. Then put dielectric grease in both fittings before you mate them back up.
Old Mar 23, 2012 | 05:51 PM
Dallas 13's Avatar
Dallas 13
+1 UltraNutZ has it right again!
Old Mar 24, 2012 | 09:40 AM
TheButler's Avatar
TheButler
Default Speedo shutting down
I have the same problem with my 01 Road Glide. I also have a Baker 6 speed tranny so mine also has a calibrator between the sensor and the speedo. I have tried new speedo, 5 new sensors, 6 new calibrators, rewired from speedo to calibrator, new speedo plug and pins. I have got it now where it works without the calibrator but its incorrect. Voltage coming back to the speedo from the sensor is lower than going to the sensor. That is the only thing I can find. After about 1/2 mile with the calibrator in the speedo drops out. I rode the bike for over 20k miles after the installation of the 6 speed with no problems. Grasping for straws here. Any suggestions would be helpful.
Old Mar 24, 2012 | 09:43 AM
soft 02's Avatar
soft 02
Here is the fix!
http://www.ebay.com/itm/HARLEY-SPEED...ht_1596wt_1398
Old Mar 25, 2012 | 06:37 AM
UltraNutZ's Avatar
UltraNutZ
Have you contacted baker support? If the speedo works without the calibrator (regardless of whether it's correct or not) then that tells you where the problem lies at least in my opinion
1-877-640-2004
Old May 6, 2012 | 05:35 AM
user 735353424's Avatar
user 735353424
Default Deuce speedo
Hi! I have a speedometer on Deuce, but I do not have the plug. Where can I buy this plugin?. What has the catalog number?. The plug is small and has 12 pins. Where can I find a description of the plug?. Please help. Image : http://img341.imageshack.us/img341/1616/wtyczkaq.jpg
Old May 7, 2012 | 06:59 AM
UltraNutZ's Avatar
UltraNutZ
what year is your deuce?
Old May 7, 2012 | 10:26 AM
user 735353424
I have the Evolution from 1989. I put the Deuce (2006) tank with console. Speedometer is original but I have no plug-ins. Looking for pin description of the speedometer.
Old May 7, 2012 | 11:37 AM
UltraNutZ's Avatar
UltraNutZ
i thought (and I could be wrong) that in 2006 is when they changed from a 12 pin plug to a 6 pin plug. What is the part number on the speedo please?
