Bike won't start
Old Feb 7, 2013 | 05:43 AM
notofthisworld's Avatar
notofthisworld
Default Bike won't start
I stopped to get gas, went to start the bike nothing. I get a loud clicking noise from the starter.
I have a 2008 sportster 1200 custom.
About 3 months ago I put a new starter relay and a new system relay in.
About 6 months ago I put a new battery in. I'm getting 13 v of the meter.
How do I determine if it's the starter or the starter solednoid ?
And where is a good place to buy one?
Any recommendation on what kind to buy?
Thanks in advance for your input.
Old Feb 7, 2013 | 11:37 PM
mconner's Avatar
mconner
Voltage should be 12.6 on volt meter. Try breaking the starter lose and see if it will spin when you put juice to it.. Might just be a bad solinoid which would explain the loud clicking noise is charecteristic of low voltage getting to the starter or even more characteristic of a bad solinoid . Check all your connections make sure thier nothing lose anywhere just as a precautionary measure. Im old school all bikes I built had and ole kick starter and a joe hunt magneto system. Didnt even have a battery.
Can you start it by poping the clutch while somebody pushes you? Just a couple things to try. Good Luck Bro
Old Feb 9, 2013 | 10:13 AM
Imold's Avatar
Imold
Another possible culprit is the negative battery lead, where it attaches to the bike. It isn't real easy to reach with a wrench, but don't be tempted to short the lug and nut with a wrench, could make a mess of things if it arced (seen that happen on cars, but they're bigger and can take it).
Old Feb 9, 2013 | 06:22 PM
aquadave's Avatar
aquadave
Check your timing sometimes backing down a little makes a big difference
metalfarm
21
Jun 1, 2016 07:30 PM
Rescuediver1982
EVO
Jul 28, 2015 08:39 PM
bg3075
Dec 20, 2014 07:23 AM
notofthisworld
Engine Mechanical Topics
Feb 10, 2013 07:35 AM
lwrnc_miller
EVO
Mar 25, 2010 05:32 PM
