Left turn signal not working
Old May 28, 2013 | 09:13 PM
redskins32's Avatar
redskins32
Stage II
Default Left turn signal not working
I have a 99 Roadking that has had a problem with the left turn signal periodically not working since I purchased it 3 years ago. I just lived with it until last weekend when it just stopped working for good. I have checked the power input/output at the switch and it's good there. So my next step was to check the power input/output at the TSM. The problem now is that the TSM is not where it is suppose to be according to the service manual I have(Clymer manual states it's in the backbone under the seat) I have traced the wire hareness back from under the tank to the right side where I found an 8 pin connector that seems to run under the engine on the right side. I disconnected it and checked that it has a power pulse from the right turn signal at the connector but not from the left turn signal. Any help on where the TSM would be located or other avenues of troubleshooting this problem would be greatly appreciated!!
Old May 29, 2013 | 12:06 PM
asa1199's Avatar
asa1199
https://www.hdforums.com/forum/touri...ol-module.html
Old May 31, 2013 | 09:43 PM
redskins32's Avatar
redskins32
Stage II
Thanks for the link. I walked up to the bike, turned the handle bars to the right and there it was. I will be continuing the troubleshooting process on this weekend now that you helped me locate the TSM that was suppose to be "under the seat". Thanks again.
RyRy
Jun 28, 2018 07:34 AM
jackpell
Sep 6, 2014 07:04 AM
128auto
May 20, 2012 09:59 PM
EG Rider
Jul 10, 2010 02:54 PM
maa148
Aug 7, 2008 10:59 AM
