Battery tender ground location-
Old Jul 7, 2014 | 09:40 PM
Deucedog's Avatar
Deucedog
Default Battery tender ground location-
After returning from a 1500 mile road trip I discovered that the ground lead from my battery tender had broken off at the battery. For those of us that know the Deuce we know that there is absolutely no spare room under the seat to do anything. So my question is whether I need to have the ground lead actually attached to the battery to allow the tender to properly charge the battery. Can I attach it to the main ground to the frame that's under the seat instead?
Old Jul 8, 2014 | 06:58 AM
nhrider1's Avatar
nhrider1
Either ground should be OK, as long as the neg. battery cable is still in place.
Old Jul 9, 2014 | 05:26 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Any good connection to the frame is fine.
Old Jul 9, 2014 | 09:53 PM
Deucedog's Avatar
Deucedog
That's what I was hoping. I figured it was at the other end of the negative/ground cable so it should be good. But, I just wanted to check with you guys first.
Thanks for the reply
HOG WRANGLER
May 8, 2010 03:17 PM
Shark46
Feb 28, 2009 04:31 AM
Handycam
Nov 20, 2008 03:25 PM
tmitchellof PG
Jun 24, 2008 09:21 AM
Hidalgo
Jan 6, 2008 12:25 AM
