Breathing Problem/ oil consumption
Old May 28, 2009 | 06:32 PM
tgaetto's Avatar
tgaetto
Default Breathing Problem/ oil consumption
So it appears I have a bad intake valve seal rear cylinder and I am also sucking a lot of oil through the TB? I run the oil a little low and I am finally tired of the usage and wondering- SOOOOOO time to fix it!!
Look at the rear cylinder pic and the oil at the rear behind the valve also the oil in the rest of the shots.
UPDATE here is a shot of the bad seal....
Comments?
REAR
FRONT
Bad seal should be round roght
Old May 28, 2009 | 09:06 PM
hogbag07's Avatar
hogbag07
I would have them flowed while there off the bike and have bronze valve guides fitted or find a set off heads for a 06 dyna or 07,08,09 models as they reportedly flow better theirs all ways a few on ebay with low miles.
Old May 29, 2009 | 06:08 AM
tgaetto's Avatar
tgaetto
These heads have been ported, cc-ed and flowed they are the SE performance heads so I am thinking just the valve seal should do it? I am more concerned with the oil in the TB there was a lot which leads me to believe high crank case pressure???
Old May 29, 2009 | 04:11 PM
tgaetto's Avatar
tgaetto
PHIL? any thoughts??
Old May 31, 2009 | 10:35 AM
PhilM's Avatar
PhilM
You'll frequently see oil run out of the intake when you pull the TB. Often, it what is being sucked back in via the crankcase breather vents that "usually" are plumbed back into the air cleaner backplate.
In this case, it appears to be coming thru the valve guide. It looks like a little drop at the bottom of the guide in one of the pics. Additionally, the back side of that valve has some seriously burn on oil. Looks like a safe bet that this one's leaking.
You're right.... I've been out riding!
"If" you have been running the breather vents back into the air cleaner, take this opportunity to route that to an external catch can. It will help in a number of ways. It will prevent the oily crap from blowing back into the TB and fresh charge. Furthermore, the air that is venting out is HOT. Heat is not your friend here either. The cooler the incoming charge, the more efficient the burn. Translation: More POWER!
Old May 31, 2009 | 11:02 AM
tgaetto's Avatar
tgaetto
Do you think a mis aligned pump could cause enough presure to blow the dip stick?
Mcdrty
EVO
27
Jul 3, 2018 02:22 PM
Dazzauk
EVO
52
Apr 4, 2016 03:55 PM
Old-Evo
EVO
31
Sep 28, 2013 02:41 AM
reserve
Jun 16, 2012 01:28 PM
Hey Zeus
Shovelhead
Apr 23, 2011 12:16 AM
