.030" head gasket...... Worth it?
Old Oct 16, 2014 | 12:56 AM
ridedaddy's Avatar
ridedaddy
Default .030" head gasket...... Worth it?
2013 street glide, I'm installing a set of andrews 57h and s&s lifters. Is the comp bump of a cosmetic.030" head gasket worth the labor for this cam? Also if I'm taking the head off is there any benefit to using adjustable push rods or can I use the stockers and cut them out later if I'm doing work in the future and need them to keep from opening the top back up? I'm just not sure if the stockers will put the lifter near the center of the lifter bore or if the base circle of the 57h is the same as the stock cam for that matter? As always thanks for the knowledge.
Old Oct 16, 2014 | 10:49 AM
djl's Avatar
djl
I am not positive about the 57 base circle but believe it to be about .020" smaller than stock. You could call Gary at Andrews and confirm. That being the case, I would install adjustable pushrods to mitigate against potential valve train noise that might result from the introduction of an extra .010" in the valve train stackup. The .030" head gasket is more about tightening up the squish band than increasing compression. I am afflicted with "tinkeritus"; a terrible affliction. The voices in my head would force me to pull the heads and install the .030" head gasket for both reasons, just because I can. However, I think the .030" head gasket decision is one you will have to make.
Old Oct 17, 2014 | 08:51 PM
UltraNutZ's Avatar
UltraNutZ
Ridedaddy. Djl is correct. No go on stockers.. already confirmed with Gary. Since I couldnt, I said what the hell and ported heads and installed .030
Static is now 10.38:1 with stock pistons
Old Oct 18, 2014 | 09:10 PM
HD Pilot's Avatar
HD Pilot
I like to work on my bike as much as riding, but even so I would not go to the trouble of taking my cylinder heads off just to put .030" head gaskets in. But with a big bore and/or headwork, now you have a really good reason to get to work.
Old Oct 19, 2014 | 08:56 AM
UltraNutZ's Avatar
UltraNutZ
if you're looking for a bump in compression then yes it's worth it. Stock 103 heads at 85cc with .030 will get you to static 10.1:1 roughly.
SportbikeCO
Engine Mechanical Topics
16
Mar 6, 2017 09:44 AM
steve303sg
Sep 1, 2013 02:18 AM
northeastconfederate
Exhaust System Topics
14
Jul 14, 2011 06:54 AM
carltex
Dec 26, 2010 10:58 AM
the_ogre25
EVO
Mar 10, 2008 06:36 PM
