head gaskets
Old Mar 8, 2008 | 09:36 PM
the_ogre25's Avatar
the_ogre25
Default head gaskets
When ordering new head gaskets what does the "0.030" mean? Is it the thikness or the bore. If it is the thickness would it raise or lower the compression?
Old Mar 8, 2008 | 10:17 PM
miacycles's Avatar
miacycles
Default RE: head gaskets
It is what the compressed thickness should be. A .030 will raise the compression ratio over the stock one. You cannot go too thin as youmay have problems with clearance between the piston and the head if you piston is above the deck at TDC.
Old Mar 9, 2008 | 09:19 AM
JakeSabre's Avatar
JakeSabre
I installed a .030 (thirty thou) Cometic head gasket on my '98 DWG, with stock heads, my CP (cold cranking pressure) went from 165 lbs to 170 lbs, this is with an EV27 cam.MyCR probably went from 8.7:1 to 8.9:1. Bikes runs better.
Old Mar 9, 2008 | 10:55 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Combine the proper squish, with a good set of heads/cam and you'll see how it is supposed to run.
Old Mar 9, 2008 | 08:47 PM
the_ogre25's Avatar
the_ogre25
Would I run into problems on a 88 evo with a ev27 cam and stock heads, or would I be better off going with the stock gaskets?
Old Mar 10, 2008 | 06:36 PM
miacycles's Avatar
miacycles
You should be fine as long as your piston is not above the deck at top dead center.
SportbikeCO
Engine Mechanical Topics
16
Mar 6, 2017 09:44 AM
ridedaddy
Oct 19, 2014 08:56 AM
rg567
Jan 21, 2014 10:27 AM
northeastconfederate
Exhaust System Topics
14
Jul 14, 2011 06:54 AM
outback2970
Feb 8, 2009 01:57 PM
