best cam?
Old Dec 17, 2014 | 09:56 AM
djl's Avatar
djl
If you are considering boring, you need to make that decision first as you need that information to run the compression/CCP calcs as part of the cam selection process. Additionally, if you are going to bore, bore to 107" as suggested by Scott; free TQ/HP. Once you have decided on cylinder bore, use a compression calculator (BigBoyz is as good as any) to start running down a cam choice. 185-190psi CCP is a good target for a street build; compression releases are your friend.
Quik
Milwaukee Eight (M8)
84
Feb 16, 2025 12:31 PM
KEYBEAR
May 25, 2016 02:32 PM
WG2011
Exhaust System Topics
Apr 9, 2013 02:23 PM
yamaracer18
11
Mar 17, 2012 07:56 AM
cnnesseth
Nov 30, 2010 10:13 PM
