Woods TW555
Old Jan 18, 2015 | 11:05 PM
Oldschool79sporty's Avatar
Oldschool79sporty
3rd Gear
Default Woods TW555
I'm a newb to the site and plan on doing a lot of reading but have a ? about this cam. Lookin at it for my 08 96", do you have to do any head work or is this a bolt in? I'll hang up and listen, preciate the help!
Old Jan 19, 2015 | 05:50 AM
target64's Avatar
target64
speaking from experience with that cam, yes the compression will have to be bumped up to 10.2 to have it perform correctly on that 96er. mine was a dead turd between 2000 to 3200 rpms than it came alive to the rev limiter. especially when riding two up cruising at 50 mph and twisting the throttle to pass a car! Hillside fix that problem for me.
Old Jan 19, 2015 | 11:15 AM
saz's Avatar
saz
If you are looking to do only cams, look at the Andrews 48's. I took Scott and Kirby's advice and put them in, and what a difference! They really pull well.
Old Jan 19, 2015 | 11:26 AM
Scrmnvtwins's Avatar
Scrmnvtwins
I have the Woods 555's in my stock 13 Limited. Stock heads, valve springs, bore and pistons at 9.6:1 CR flowing through V&H Power Duals and Monster Rounds with a PCV tuner. I am happy, with the results. I wanted a little more mid to top end grunt without changing the heads or pistons and I got it.
Old Jan 19, 2015 | 11:58 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Good cam, just needs to be up at 10.2, 10.3 to show what it really has.
Scott
Old Jan 19, 2015 | 12:36 PM
dforeid's Avatar
dforeid
In a 96, I'd do the 48 if it were my bike.
Old Jan 19, 2015 | 04:23 PM
Oldschool79sporty
3rd Gear
I can get the cam pretty cheap so that was my angle. I have true duals, PC & stage 1 already installed and wanted to bump it up a little w/o a lot of major work. We do a lot of traveling so wanted a little more get up that's all. I am one to red light race with guys too so I won't lie that I'd like to thump their 103's red to red! So if I do the cams which adj rods are best, alum or steel? S&S or Andrews?
Old Jan 23, 2015 | 01:50 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Default steel
I had aluminum Revtech adjustables with .600" lift springs and over time the end of the pushrod barrell started to get stress cracks, I now have S&S steel adjustables.
Old Jan 23, 2015 | 03:51 PM
Hillsidecycle.com
Sponsor
We use nothing but S&S 4130 steel pushrods here.
Scott
Old Jan 24, 2015 | 10:14 PM
Oldschool79sporty
3rd Gear
Scott,
Is the S&S kit rods and tubes or a complete cam install kit with gaskets, o-rings, etc...?
