Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Hey guys. Looking to see if anyone has a similar set up and has dyno tune results. I have a 14 street bob with thunder header and big sucker air cleaner. Looking to replace my Fp3 tuner and have harley install Sert and run it on the dyno and have it tuned to maximiE performance. Does anyone know what kind of numbers I can expect to make. Also do you think installing a woods 222 would be worth the money
Everyone uses the andrew57, but i really like results others have posted with the tman 555 torqster as a true bolt in. As oldenough said a stage 1 with a Good exhaust is nonoticeable, it will lead to wanting more.
Since you are not doing anything to increase compression, make sure you choose a cam that works with stock compression. Many performance cams are designed for higher than stock compression and you will be disappointed with your results if installed in your bike. In other words, review the cams' specs and manufacturers' recommendations before purchasing.
