Big bore build chirping on cold start
Old Jul 16, 2015 | 03:37 PM
stic2it's Avatar
stic2it
Mechanic tore down the rear cylinder w/ 180 compression. He said the compression ring was upside down and one of the rigs had a larger gap than it should have. I was almost positive I put those rings on right but I am human. It was letting some oil past so hopefully that fixes it. The front cylinder he didnt recommend tearing down since the compression is holding. I hope to ride her home on Saturday.
Old Jul 19, 2015 | 06:42 AM
northeastconfederate's Avatar
Keep an eye on your engine oil level and primary oil level. If the compression ring was upside down for 1,000 miles, you were pressurizing the crankcase for quite a while. The sprocket shaft seal could have gotten pushed partway out. This will cause engine oil to enter the primary, filling it up.
cajun1957a
Aug 28, 2018 02:09 PM
stic2it
Engine Mechanical Topics
Mar 12, 2015 08:26 PM
atwa
Oct 30, 2012 11:18 AM
deadhead63
Nov 10, 2007 11:38 AM
kbiforce
Aug 26, 2006 05:03 PM
