Big bore build chirping on cold start
Old Mar 12, 2015 | 08:44 PM
stic2it's Avatar
stic2it
Default Big bore build chirping on cold start
So I just did a FM 107 build, when it's freezing or below with a cold engine that's been sitting overnight my engine will chirp for a few seconds. Is this something I should look into. When it's warm out, no problem at all. I have manual releases and it seems like it comes from the left side of the bike
Old Mar 13, 2015 | 07:06 AM
prodrag1320's Avatar
prodrag1320
ex valve not sealing all the way,why are you starting it when its so cold? your not doing it any good,ill tell ya that
Old Mar 13, 2015 | 07:56 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
What's the outfit say, that you purchased it from?
Old Mar 13, 2015 | 04:40 PM
stic2it's Avatar
stic2it
I don't start it just to start, I'm usually about to hop on it to ride. Like this morning when I was on my way to work. It was 29 degrees out, it chirped for a few seconds
Old Mar 15, 2015 | 07:04 PM
stic2it's Avatar
stic2it
Folks say it's most likely the Head gasket. I'm bringing it to my Indy to look further. Fuel Moto didn't build it, I did
Old May 20, 2015 | 04:09 PM
stic2it's Avatar
stic2it
Still haven't found the culprit, exhaust valves are completely dry, no oil found when I removed the exhaust. I didn't see an exhaust leak when testing with cigar smoke but I put my hand up near the front head and felt some air but then closer look and I have an oil leak coming from the rocker boxes. I think it was my fault, I went back in them and reused the gaskets. Can that cause a chirp? I got a James kit and will change them out
Old May 20, 2015 | 04:35 PM
prodrag1320
do a leak down when its cold,then leak it down when its hot (or warm).if its a ex valve,that`ll show it (seat leaking wouldn't show up as wet)
Old May 20, 2015 | 11:04 PM
Ed Ramberger's Avatar
Ed Ramberger
Are you sure it's not just a release that takes a few seconds to close?
Old May 21, 2015 | 08:56 AM
stic2it's Avatar
stic2it
I thought that might be it but if I start the bike without the cr's it still makes the chirp. It only makes it for all of 1 second.
Old May 21, 2015 | 11:01 AM
Hillsidecycle.com
Sponsor
Head gask?
Exhaust gask?
Hard to diagnose over the internet.
What solution/suggestion does the outfit you purchased from, offer?
Scott
