Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I'm not "reluctant to utilizing a good fuel management system". Not sure how you got that from my posts. I'm well aware of the fact that if I port the heads, I will need additional fuel. I have modified a few bikes in the past. How exactly do you know I've left 5-10 hp/tq on the table by utilizing the HD re-flash?
Well, I figured that since you have not employed a good fuel management system over the HD flash that you were reluctant to employ a good fuel management system. I know you left some TQ/HP on the table because the HD flash is one size fits all, adds a bit of fuel across the rpm range but not necessarily where needed, raises the rev limit and is designed for a specific combination of HD parts. You have removed the cat and installed slip ons which I assume are aftermarket, so the flash is not designed for your application. Additionally, I have seen it proven on a local tuner's dyno (happens to be one of the best in the country) over and over again.
No disrespect intended but I don't care how good you think your tuner was with the Redshift cams, which are not that aggressive, if he couldn't resolve your driveability issues, you should have found another tuner.
