Head porting a stock 103"
Old Apr 19, 2015 | 07:06 PM
Bannana Boat's Avatar
Bannana Boat
Default Head porting a stock 103"
I have a 12 Streetglide with a stock motor, high flow aftermarket intake, HD reflash, cat removed and slip on's. Not real happy with the top end pull. Anybody ported the 103 without any other internal engine upgrades and had good results?
Old Apr 19, 2015 | 08:17 PM
cdonis's Avatar
cdonis
If I was to make 1 change to the engine I would do cams. I don't think heads alone will do ya. Both would for sure.
Old Apr 19, 2015 | 08:33 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Just porting the heads will result in squat! You need to improve the overall parameters of the engine by changing the way in which it pumps air.
Old Apr 20, 2015 | 06:25 AM
prodrag1320's Avatar
prodrag1320
cams & mild 1.900 headwork would give most bang for the bucks.S&S .570`s would be a good choice
Old Apr 20, 2015 | 07:45 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
One of several Wood cams, Andrews 57, or as Kirby mentioned the S&S .570.
A 58mm t/body with a port match would be a home run, at the time of the head porting.
Scott
Old Apr 20, 2015 | 09:09 AM
djl's Avatar
djl
The first thing you need to do is install a good fuel management system like the TTS Mastertune or DJ Powervision and get a proper tune; that might give you what you need; the HD reflash has given you nada. A set of SE204 cams (with 1.7 rockers on the intake) or TMan 555 Torkster cams and a dyno tune will wake the bike up. As others have said, headwork at the same time would be the full monty but if $$$ is an issue, you could take it in phases which would require an additional dyno tune and add to the cost.
Old Apr 20, 2015 | 09:13 AM
Bannana Boat
Reluctant to do cams. Did Zippers 575's in my 06 103" Fatboy and didn't like what it did for the low speed drive-ability. I ported the heads on that bike and saw decent results.
Old Apr 20, 2015 | 09:23 AM
kishstl's Avatar
kishstl
That sounds more like a tuning issue, than the result of the cam. Even a stock cam poorly tuned can have poor low rpm performance.
Old Apr 20, 2015 | 09:40 AM
Bannana Boat
The guy was pretty sharp but couldn't work out the aggressive timing of the cam on the dyno. Tried many adjustments and got it as tolerable as possible.
Old Apr 20, 2015 | 09:50 AM
djl's Avatar
djl
Driveability issues are usually tuning related; very poor reason for being reluctant to upgrade cams. Plenty of strong running 103s with no driveability issue with Stage I plus cam upgrades but a good fuel management system and tune are necessary to optimize performance and eliminate driveability issues. The '06 and later heads are not all that bad; cleaned up with a SERDI multi angle valve job actually flow fairly well.
The problem with your current configuration, which you seem reluctant to recognize, is the HD flash in lieu of a proper tune. If you install heads, cams, or both, you will need a good fuel management system to tune the motor. Why not get the fuel management system and tune the motor you are running; I would bet that there is 5-10 TQ/HP yet to be pulled out of the current configuration. Then you have a baseline on which to build.
