Newb Cam question...
Old May 1, 2015 | 09:54 PM
ghost81's Avatar
ghost81
Default Newb Cam question...
Okay I have a 05 night train fxstb it's got the stock 88b motor with Thunderheader, big sucker, and mikuni42r
I'm gojng to change the cams and go with the Andrews 37's, and yes I do plan on porting the heads later probably big Boyz and also big bore
My question is... I'm going to put the SE hydraulic tensioner kit on the bike the PN is # 25284-11, does the normal chain drive 37s fit with this kit or do I need to get the 37n conversion cams? Thanks
Old May 1, 2015 | 09:57 PM
QC's Avatar
QC
The normal cams work with that kit.
Old May 2, 2015 | 09:36 AM
djl's Avatar
djl
No need for conversion cams but the 37 will be "soft" in a stock TC88; not enough compression. S&S 509 or Andrews 26 would be better choices. Early heads are limited to .510" lift but when you have your heads worked you can go for higher lift cams like S&S 570, TMan 590, etc.
Old May 2, 2015 | 02:08 PM
fidel's Avatar
fidel
or if you like the 37 check the 57 same timing with more lift
Old May 2, 2015 | 04:24 PM
djl's Avatar
djl
I missed that the OP bike is '05; he could run the 57 with no issues. However, '05 was the worst year for OEM heads; they don't flow well enough to take advantage of the higher lift. The 57s will also need more compression just as the 37s will. Both are the wrong cams for a stock TC88.
Old May 2, 2015 | 09:03 PM
ghost81's Avatar
ghost81
So the 26 is a better match for the tc88 I just don't want to lose that highway power being able to roll on 4th and 5th, also want a cam that is gojng to make the exhaust more pronounced
Old May 3, 2015 | 10:12 AM
djl's Avatar
djl
If you want roll on power in 4th and 5th, you don't want the 37/57 cams. Yes, the 26 would be a better choice but IMHO the S&S 509 would be a better fit.
Old May 7, 2015 | 09:03 PM
Kaycee's Avatar
Kaycee
Did the Andrews 26 N in mine a coupla years ago they pull nice , only draw back is now I want MORE.
HD Pilot
Exhaust System Topics
35
Sep 22, 2014 09:04 AM
tbyji2
Dec 7, 2013 05:15 PM
CigarDogHD
Aug 6, 2011 09:47 AM
creep1
Dec 12, 2010 06:42 PM
Quickie
Jul 28, 2007 08:19 AM
