chirping on deceleration
Old Jul 1, 2015 | 07:58 PM
2007fxstc's Avatar
2007fxstc
Default chirping on deceleration
It's driving me nuts trying to find where it's coming from. Beat clue is that it goes away when I pull in the clutch or hold a steady speed.
Thanks
Old Jul 1, 2015 | 11:49 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Have you tried lubricating the throttle grip?
Old Jul 6, 2015 | 12:16 PM
stic2it's Avatar
stic2it
Chirping from the engine on deceleration, any visual head gasket leaks?
Old Jul 6, 2015 | 12:38 PM
2007fxstc's Avatar
2007fxstc
I give up.
Gonna have the dealer do an El
Evaluation and open an ESP.
Old Jul 7, 2015 | 06:18 PM
dfwhockey17's Avatar
dfwhockey17
Check your primary chain and your drive belt, both of those 'unload' when not on the throttle and can chirp...
Old Jul 7, 2015 | 06:27 PM
Stiggy's Avatar
Stiggy
Its your drive belt.
Old Jul 7, 2015 | 08:19 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Funny thing about noises while riding is it can literally come from just about anywhere and resonate throughout.The first thing I would check is motor mounts and next what is the tension on the rear drive belt? also look for metallic residue in the belt from the rear pulley that also could cause it. Pulley will look like it's pitting but will still function.
Old Jul 7, 2015 | 09:14 PM
Harleycruiser's Avatar
Harleycruiser
Belts squeek.
Spray it with silicone and see if it goes away.
Old Jul 8, 2015 | 09:24 PM
GraemeR's Avatar
GraemeR
My Sporty Chirps!
Only for the first mile when the rear belt is cold. Once it warms up the chirp is gone!
Old Apr 4, 2021 | 08:10 PM
charleskmoore2's Avatar
charleskmoore2
Thanks
I had a very similar issue. Mine would chirp as soon as I would let off the throttle just as mentioned. On the lift, it would chirp when the bike was in gear and you rocked the wheel back and forth. During freewheel, it would make a low creaking noise. My mindset is to always start with the easy, cheap and usual issues, here's what I did...
1) Adjusted belt - Nope
2) Cleaned belt and pulley - Nope
3) Cleaned compensator isolators - Nope
4) Checked alignment each time I did the steps above - Nope
5) Inspected pulley with a bright light - Ah ha! Two hairline cracks I could only see at an angle. OBTW, they're hollow.
6) Replaced pulley - Problem solved
Hope this helps someone searching for an answer to what they can't seem to find after doing some of the steps above. Most of the time this issue it stopped by step one. This wasn't the answer I wanted, but it was what I ended with.
rsking45
Engine Mechanical Topics
Jun 3, 2016 12:08 AM
Gearhead3
Oct 13, 2010 08:29 PM
neverdown
Jun 20, 2009 07:13 AM
vulhalla
Sep 8, 2006 04:29 PM
TowJam
Oct 6, 2005 01:46 PM
